Several years ago I went to my local tool rental to get a drain snake. 'The tip's broken off but hang on a second and I'll weld it back on for you' the guy at the counter said. I took it home and sure enough, on the way back out, the tip broke off two feet down the old iron drain pipe from my ground floor lavatory. The lavatory drained OK, and I couldn't figure out what to do, so I hoped the plumber elves would take care of it and I put it out of my mind. Now suddenly water from the lavatory won't go down at all. Or, a full basin might take 24 hours to drain. When I try to insert a snake it hits a hard blockage which I assume is the old coiled tip of the broken snake. So what to do? All I can think of is to go into the crawlspace and cut the old iron pipe, pull down the vertical part and replace it with ABS and a no-hub. In the picture below you see the layout. My question is... If I cut the pipe at the red line will it drop down, or is it likely fastened inside the wall somehow? Advice? Other ideas? Many thanks.
