Hello, I am replacing an old built in vanity with a new one and am trying to figure out what to do with the supply and drain lines. I have attached pictures of the existing configuration and the new vanity that will be going in. Before installing the new vanity I will be tiling the floor and walls. Originally I thought I had this all figured out because there is about 3" under the vanity and on the left and right sides but only about 1.25" behind the vanity available. I was going to cut off the supply lines near the floor, put 90's on back to the wall and then 90 back up the wall. Then install new valves and cut some small holes in the vanity to give access to the valves and use stainless braided lines to the faucet. For the drain I was going to bring it down the side of the wall, go under the vanity to the back where the slot is then come up and into a p-trap. However, I realized last night that this would create an s-trap which I understand is a no-no. So... any suggestions on how to install this without having to hack into my vanity? I do have room to go between the side of the vanity and the wall to get to the back wall but then there is not enough room for the drain line to run behind (unless I were to cut away the drywall and notch a bit of the 2x4's to create a groove for the drain line.
Thanks,
-jeff
Thanks,
-jeff
