Drain in Utility Room next to Pressure Tank/Tankless Water Heater?
Discussion in 'IPC Plumbing Code Questions' started by mariposuerte, Oct 13, 2021.
  1. mariposuerte
    mariposuerte New Member
    Oct 12, 2021
    Rosanky, Texas
    We will be putting in a tankless on-demand water heater and water supply pressure tank in the utility room in the basement. Should I install a drain in that area leading to the basement ejector basin or can I get by without?
  2. James Henry
    James Henry In the Trades
    Jul 23, 2019
    Billings, Montana.
    Put a drain in.
  4. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    AS long as you make sure the trap seal is always refreshed it is a great idea
  5. James Henry
    Jul 23, 2019
    Billings, Montana.
Similar Threads: Drain Utility
IPC Plumbing Code Questions IPC minimum depth to drain pipe under basement slab Oct 13, 2021
IPC Plumbing Code Questions Drainage Water Test in Basement pre-slab rough-in Oct 12, 2021
IPC Plumbing Code Questions Toilet Drain 4" Long Sweep 90? Sep 7, 2021
IPC Plumbing Code Questions Reduce sink drain question Aug 14, 2021
IPC Plumbing Code Questions Toilet drains tee Dec 26, 2020
