John in Klickitat
I would like to put a Fleck water softener next to my washing machine and somehow use the washing machine drain pipe. The problem is the drain pipe is 35" tall and the drain outlet on the Fleck cabinet is lower than that, with 27" height.
Is there a way to use the washing machine drain pipe for the water softener's drain that would meet code? I was thinking of putting a wye on the drain pipe low and catching the output from the water softener in a lower vertical pipe off the wye. But it seems like there would need to be a backflow valve to prevent the water and suds from the washing machine from spilling out.
Is there a good solution for this that would likely meet code? Sorry if this is a really basic question with an obvious solution.
