Drain configuration
Jklompus3
Illinois
Trying to connect my utility sink to the rough-in done by a plumber and having a hard time getting it attached due to tight clearance. I came up with the configuration in the first attached picture but inspector says it is too restricted due to sweeps at the top. He wants a straight tailpiece into the trap. Any ideas? I tried two 45s but not enough vertical distance. I also tried the Snappy Trap (second picture) but hate to use those types of things.
wwhitney
Berkeley, CA
While I may agree that the arrangement is suboptimal, did he give you a code citation prohibiting it? If not, it's allowed.
Would a straight down tailpiece intersect the tubular trap arm as you currently have it? If so, then there's no solution with a straight tailpiece into a trap that doesn't involve removing the solvent weld wye and redoing it.
With the two 45s, did you try that on the vertical upstream of the trap? Seems like that should fit, but would not be a straight tailpiece into the trap. However, there's no requirement for a straight tailpiece into a trap.
Cheers, Wayne
Jklompus3
Illinois
Cheers, Wayne
Yes, straight tailpiece would very nearly intersect drain wye male fitting. Picture of 45s attached; very little distance and would need to create some very short stubs to connect slip joints.
wwhitney
Berkeley, CA
On the last picture, looks like if you pull the trap outlet elbow farther out of the trap adapter, and rotate the trap j-bend inlet closer to the trap adapter, you can end up with the trap j-bend inlet closer to the tailpiece (as seen from above). That should let your two 45s line up.
So then you just need to figure out how to make the connections. Rather than use 45s with SJs on each end, it would be easier to work with a 45 with a SJ inlet and a tubular outlet. Then you can just do tailpiece - SJ 45 - SJ 45 - ptrap j-bend, without using any short sections of pipe.
They make "double slip joint tubular offsets" that have two 45s bends in the tubular part, with SJs at each end. If you get one of those and cut it in half, you end up with (2) SJ x tubular 45s.
Cheers, Wayne
