John B H
I'm running water from my well (pitiless adapter) to a house with a crawl space; no basement. I leave the property in the winter and want to drain everything to below frost line. Is there a valve I can put in the well drop pipe between the pit less adapter and the submersible pump that I could manually open and close? Or is there a valve I could put somewhere in the line from pitless to house, below grade with a small drain field, that I could manually operate? I know I can drain everything above grade at the house but I'm trying to figure out that short distance from grade to frost line. Thanks.
