Greenmonster123
Active Member
Are there any purpose built valves that can drain the lateral back into the casing that can be actuated from the surface?
A bleeder would do that when combined with a closed valve topside.
Suction pump with a foot valve?Are there any purpose built valves that can drain the lateral back into the casing that can be actuated from the surface?
I was incomplete in my first post. Closing a topside valve would not let air in for the line to drain unless you also had a snifter valve topside. You could remove the pressure by opening a topside drain valve at the tank Tee and leave it open to let air in while the bleeder drains the line. Under pressure the bleeder would not open so it would work normally. The bleeder might drip a little while under pressure.Yes I thought of that but in the warmer months I would like it to work normally...
You could install a Tee and a street elbow with a ball valve below the pitless (assuming there is room in the casing) and connect a long rod to the handle of the valve. Just bend the handle 45 degrees so it is never fully vertical when open and then the long rod can actuate it.
How about two pitless adapters in the casing. One for real use, and the other not connected, but used as a parking spot for when you want to drain the pipe. Make sure not to energize the pump when parked.
Oh, wait... just have the one trapezoidal pitless, but lift it a bit when you want to drain the pipe.
I guess I could do that with my thruway MCKS pitless, and leave it dangling from its normal support but with the leg retracted when trying to drain the horizontal pipe.
