Do You Use Plumber's Putty or Silicone under the Escutcheon Deck Plate Rubber Gasket?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cfipp, Dec 3, 2018.
  1. cfipp
    cfipp Member
    Apr 21, 2007
    Florida
    I am getting ready to install a new Moen kitchen faucet. It is a single-handle faucet and I will be using an escutcheon deck plate to hide the left and right holes. The deck plate comes with a rubber gasket. The instructions simply say:
    • Place Deck Plate Gasket onto Deck Plate.
    • Firmly snap Deck Plate Gasket onto Deck Plate.
    • Place Deck Plate on mounting surface and install Faucet Body in hole on sink.
    Do you use a rope of plumber's putty or a bead of silicone under the deck plate rubber gasket? Would that add additional protection for leaking under the sink, or is that a bad idea for some reason?
    Thanks very much!
    Carol
  2. cfipp
    cfipp Member
    Apr 21, 2007
    Florida
    I referred to the gasket as a "rubber" gasket but I just got it out of its packaging and what a misnomer! That gasket is not rubber nor silicone - - it is just hard plastic with a very, very thin roll/gasket of a spongy neoprene-like material. Almost nothing there to prevent water from running right under the plate and down any of the three holes. (And not only that; you can in no way "firmly snap" the gasket onto the deck plate. It sort of sets into the deck plate grooves but it doesn't remain attached - it slides right off - and it sure doesn't "snap". )
    Here are photos of the gasket and the thin rope of neoprene (or whatever it is):
    So would it be ok to also apply some silicone or plumber's putty under that gasket? My sink is a white enameled cast iron.
    Carol
  4. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    Plumbers putty will eventually harden and it really wont help here. If you're worried use a little "clear" caulking. Apply a thin bead and after the faucet is tighten down wipe away the excess. You be surprise how much pressure does get applied to these gaskets to seal up. Anything too soft and they'l split apart. The edge of the faucet base is quite sharp. There are millions of these out there and you rarely see these leak any. Just remember that the water is laying there with no pressure.
    cfipp likes this.
  5. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I would. I am not a plumber.
Similar Threads: Plumber's Putty
Plumbing Forum, Professional & DIY Advice Blanco silgranit sink - silicone or plumber's putty? Mar 11, 2019
Plumbing Forum, Professional & DIY Advice Plumber's Putty Oozing Around Kitchen Sink Strainer Body Nov 9, 2018
Plumbing Forum, Professional & DIY Advice Does regular plumber's putty stain quartz? Apr 18, 2013
Plumbing Forum, Professional & DIY Advice is plumber's putty under plastic okay? Aug 5, 2010
Plumbing Forum, Professional & DIY Advice plumber's putty - not on granite? Jul 23, 2009
