MidtoupperMichigan
Have a cottage we moved to a new 5 block tall foundation just put in and crawlspace is 5 blocks tall. I like the efficiency of the hybrid water heaters but they look to be taller than any other water heaters out there. This will be in northern Michigan so its not going to be too warm in crawlspace for the hybrid to pull heat out of the air so I am thinking of just going with a Rheem 38 gallon short 31.5" tall electric dual 3800 element water heater even though I have natural gas, I feel its going to be simple and easy and I can shut if off at the main breaker when the cottage is not in use which will be multiple weeks in the winter and maybe a couple in spring and couple in fall when no one is at the cottage. Cottage is small 662 sq ft cottage 2 bed 1 bath. Will have shower/tub and bathroom sink and washer and dishwasher and kitchen sink but most often it will be 2-4 people using the cottage at a time. The Rheem is sold at Home Depot for around $400 or so but is rated at "approx" $296 a year which is relatively low for an electric model especially since i plan to turn it off when not in use. I have considered putting it on the main level of the 1 story cottage so its less water line distance and a bit warmer but I suppose I will need to be heating the crawlspace area anyway for the water pipes that will be running down there and sewer pipes.
