gadolphus32
I have an old cast-iron radiator in my attic. It has a leaky valve, which I tried to replace but I can't find the right size (I'm wondering if the thing is so old that it is a non-standard size, because no standard valve that I have tried works to connect to the radiator...although the pipe coming into the system is a standard 1-inch).
No one lives in my attic, so I was just going to cap this radiator off and be done with it.
My question is whether I can cap just the pipe that feeds water into the radiator, or if I need to cap the other end, too. The supply end will be super easy to cap, because I already removed the valve. The pipe on the other side is much more difficult to deal with because of access issues, and I am worried that if I start moving things around too much on that pipe, I'll break connections somewhere else in the system. So I'd just as soon leave that other end be if I can.
The radiator currently has no water in it. I assume that if I cap just the supply pipe so that no more water can come up to that part of the system, there is no need to cap the return side. But I thought I'd check with you professionals before I make a dumb assumption.
In case it's not clear, this is a hot water (not steam) system. The radiator in question is the only one in the attic, and the highest point in the system.
