So there has been a gap, while I was able to get a few things done with our place. I was able to finally get into the attic, and put in a sensor for the heat. So today is a day, that the outside temps are around 85 degrees, and the sensor is already up to 110 degrees(1pm). So it is clear that the attic is getting very hot. The insulation looks like it is pretty good, so I don't see that being a problem. I think that a big problem is the venting. There is a vent in the front of the house. THere is a similar size vent in the back of the orginal hosue that is going into the expanstion of the back of the hosue. there isn't a vent on the expansion of the house. I don't see any type of soffets on the bottom part of the rooflines that help with the venting. So my question is which of 3 choices should be looking at to hep alleviate the problem (or all 3 maybe).
1)If I should look at trying to get a vent in the back of the house to allow the back to vent outside.
2) Should I try some sort of radiant barrier on the rafters?
3) Should I go back to considering the attic fan on the main part of the house to get the primary roof/attic area cooler.
Now that I have access in, I'm really into trying something soon to fix the problem.
