I am guessing that you mean that the pump goes on every 15 minutes.Stable at about 15 minutes between pressure drop cycles ...what does this mean?
If so, your next leak is smaller than the one you found already.
I would try to translate minutes into gallons. Right after the pump turns off because the pressure rose, open a faucet, and measure how much water comes out by the time that the pump turns on again. You can fill one or more buckets. You can use a 5-gallon bucket, and estimate the fullness. Or check for the change in weight.Been trying to watch for cycles but can't stand around and wait ...been going back every few hours ... the loss if pressure may be less than yesterday ...
What would constitute a "normal" or "reasonable" loss of pressure on a system like this ...lake pump, small pressure tank with integrated irrigation system and 500 feet of line with three bibs?
Latest ...
Sat and watched on and off as pressure dropped from 37 to 30 and made the switch.
Took one hour seven minutes ...
Then took no more than one second to pump up to shutoff at 50.
