Nick Kendall
Hello I have done allot of reading and studying still am struggling with the flow in my radiant heat system. I previously had it working great in my house then I got a bigger boiler and added my garage and am thinking I need a bigger pump
I currently have 9 loops of 3/4 pex Each within 10’ of 300’ to the manifolds
A pair of 5 loop manifolds one has house lines and the other has 4 garage lines I had it started last weekend with just my 9kw boiler but I found a 15kw a friend had so I switched to that and got it started up but it had a circulation pump on the bottom side so I just left it in place and am using my original taco 07 after the expansion tank My issue seems to be that I can only get flow to register through one of my manifolds at a time and when it flows it’s max if 1-2 when previously I was able to get more, and as soon as I try to turn open both manifolds I am not registering any flow on any meters
I have an f5 Nd f7 pump currently
I would think just a bigger pump but since adding the just a different boiler I lost flow pressure. Any help will be greatly appreciated thanks Nick Kendall
