My Roman tub diverter valve seeps to the shower head when it’s turned off. I replaced the stem with a Newport brass 90110 which was a match from the current stem, still seeps at the same rate… We haven’t lived here long, so not a 100% sure that it hasn’t always done that. I am thinking that this has always been the wrong stem as if you put pressure on the diverter handle it does slow it down. I have also tried adding spacers under the packing nut, which were there prior to the new stem, but no luck. The spacers are like thin washers. I can see that the hot and cold rough in specifies Andre collections but can‘t verify the diverter is the same, I would assume so. I have searched and searched all over the internet with no luck.
Thanks in advance for any help!!!
