Dish washer & kitchen sink shouldn’t run together?
Questions1
Illinois
I used the dishwasher for first time and while it was running, I wanted to hand wash a bigger pot in the kitchen sink but when I turned the water on, the water kinda clogged for few mins and now water went down but I see lots of black dirt pieces in the sink. I can not use the kitchen sink while running the dishwasher on?
Questions1
Illinois
Water filling up when’s dish washing in the sink as using u can see. I didn’t have this problem before. I would occasionally hear something like bolo bolo blo and when I go check the sink I see the dish soap foam come up a little bit but not the problem I seee today as water fills up on one sink while I wash dish in the right sink.
Questions1
Illinois
The kitchen sink will need snaking, or at the least, check the p-trap under the sink.
I am completely new to these so I don’t understand! I didn’t have such clogging problem in kitchen sink before. I would occasionally hear bubble noise while I am doing something and when I check I would see the dish foam come out a little bit on the sink drainer . Today for first time while leaving the dish washer running on and also hand washing some dish in the sink, I see the sink clogging with water in the sink filling up on the left part of the sink while I hand wash something on right side of the sink . This is new
The dishwasher drains into the kitchen sink.
Either a connection in the wall, through the disposer, or near the disposer under the sink. If the sink is draining slowly, it will be even more affected when the water is being pumped from the dishwasher.
A typical installation where the dishwasher drains into the disposer through an air-gap fitting.
Questions1
Illinois
Thank you for the explanation but I don’t know how to fix this myself and I don’t know even what is snake or where to stick it. Should I call the plumber and explain the problem? I live in 2 bedroom condo building with 18 units. I would like a permanent solution or something that won’t happen frequently! Is it a lot of work for a plumber? That would indicate how much I would pay for service. Thanks
Look at the disposer to see what it piped into it and take a picture.
Also, how old is the disposer? They will have a date code on the serial number. An old disposer can allow too big of chips out which can produce a clog downstream.
Questions1
Illinois
Dish washer stopped washing and drying now and I checked my sink and I see lots of water. It is not full and not filling up but it is not going down
Questions1
Illinois
I don’t know what disposer is honestly or where it is I am dumb about these . I called the plumber that works for many condo associations and when he has time he comes he said he will try to come in the morning . Hope he can
Questions1
Illinois
Questions1
Illinois
plumber came. I explained that I used the dishwasher for the fist time since moving in here and that clogged my kitchen sink and water filled up my sink. I used to have very minor slow drainage in the sink for long time like soap foam coming out sometimes while hand washing dish but NOTHING like last night. He turned on the water for sometime and water wasn't going down. He said it is building's pipe problem and spoke with the association for me and covered the cost. He came in with long metal boxed and i could hear drilling something. I cleared out the bottom of the counter near the sink so he could work. Worked for like 40 mins maybe. going out of my room and coming in couple of times. He told me to keep an eye on the pipe and let him know if it leaks. H said he did " rodding" 45 feet down . I run the kitchen sink water and it is not clogging now. I haven't used the dish washer yet again to see if it would clog my kitchen sink. I will run the dishwasher now and see if it will mess up my kitchen sink again
