Michael Stone
A while ago we had our pressure reducer valve replaced because the plumber thought it was old and probably needed to be replaced (we weren't actually having any problems with it). I think it was a while after that we noticed that the TPR valve on the water heater was leaking a tiny bit. At the time we didn't think of the fact that the two things could be related.
So we had the plumber come out and replace the TPR valve (he said he checked the pressure as well and it seemed okay). Since he replaced the TPR valve it has been leaking a lot more, maybe a few cups a day. My thought is that since we had the pressure reducer replaced, when the water heats up now it can't flow back to the city so pressure is building up and being released through the TPR.
So I figured we probably need an expansion tank to take this excess pressure. The plumber disagrees, he think something else must be causing the problem. One thought he had was that the water might be too hot, but it seems to be about 124 degrees, which I think is okay (just a bit over the 120 recommendation). What do you think is likely to be causing this problem? Would an expansion tank be a good idea?
