Ukrop
Hi everybody!
I just found this forum and hope to get some professional opinion.
I just installed softener with Fleck 5600-SXT controller and 1.5 cu ft of resin. And now trying to set the best settings
I read through posts here and also I found quite informative site https://www.aquatell.ca/blogs/aquat...eck-5600sxt-softener-valve-for-max-efficiency.
But there are some big discrepancies...
The first question is about parameter C:
here everybody uses 32k as a multiplier for 1 cu ft of resin. So I should put 48.
But aquatell site tells about EFFECTIVE capacity and they put 30 as C...
Which one should I choose?
And the second one is about BLFC.
I read discussion here:
https://terrylove.com/forums/index.php?threads/recommended-fleck-5600sxt-program-settings.61696/
and went to check my softener. It has the same black sticker with 0.50 GPM but on the other side there is white sticker with written number 1 and printed INJECTOR DRAIN FLOW (see picture).
EDIT: looking at the picture for couple minutes I think that it could be just directional sticker??? (where injector side and where drain side?????)
So what is the BLFC in my case?
The hardness is around 25. How my settings should look like?
Thanks in advance!
Aleks
Thanks in advance!
Aleks
