Did I measure the faucet inlet connector correctly?
Arnav
Florida
Hi,
That is, given the attached picture, I would need a supply valve with a 1/2" O.D. Compression Outlet right?
Thx!
Arnav
Florida
I thought 3/8" is more popular so I wanted to double check. Out of curiosity, what makes this supply line 3/8" then? Where would you measure to see that?
I think you are asking why it is called 3/8. Originally, the tube was 3/8 OD, and the nut squeezed a ferrule tight. Those are still available, and have their merits despite being a little more work. https://terrylove.com/forums/index.php?resources/non-flex-copper-supply-riser.23/ talks about using the metal tube.
The connector you posted a photo of is probably a rubber/plastic tube with a protective and decorative braid over the outside.
Arnav
Florida
5/8" OD compression valve is not the same as a 1/2" OD Compression valve right?
I am asking since I saw valves listed as "5/8" OD Comp (1/2 Nom. Pipe)"
Thx for the help
We were basing our 3/8 compression on your digital caliper reading.
Usually a connection labeled 1/2 inch compression is for 1/2 inch copper pipe, rather than 1/2 OD. They sorta change at that point. So you have to be careful, as was the listing you just copied. "Nominal" means what we call it"
In the old days, ads would often say there was a nominal shipping charge. It took me a while to find out that meant that the shipping charge is whatever they say it is.
Arnav
Florida
This was a new question altogether. Apologies for the confusion. Let me try again
1. All good about the 3/8" for the outlet.
2. My next question is about the inlet for 1/2" copper pipe. I was looking for this Dahl 1/2" OD Comp X 3/8" OD Comp in the US and couldn't find it.
https://www.dahlvalve.com/products/mini-ball-valves/supply-stops/copper/supply-stops-611-32-31.php
I only found 1/2" FIP, sweat, etc'
I did see this Dahl one which is labeled "5/8" OD Comp (1/2 Nom. Pipe)" so wanted to make sure it is not some mere convention to designate 1/2" nominal OD and it would work on a regular 1/2" copper pipe just fine...
https://www.supplyhouse.com/Dahl-61...omp-Angle-Supply-Stop-Lead-Free-Chrome-Plated
Dahl 611-33-31 looks right to me. https://s3.amazonaws.com/s3.supplyhouse.com/product_files/611-33-31-submittal.pdf
Note you will toss the output nut and ferrule, unless you want to venture into chrome plated brass, rather than flex.
I would use a little silicone grease on the tip of the output to help the seal seat better. I would use a little pipe dope on the ferrule and threads of the input. This allows you to use less torque. You will still be tightening it as hard as you can. It is hard to get enough torque with a pair of short wrenches IMNPO. (Non-Professional/Non-Plumber)
Arnav
Florida
Thanks for all the help. I ordered a few valves. Dahl and Supplyhouse confirmed this is the right valve for 1/2" copper as well.
yes 5/8 inch od is for the copper coming out the wall 5/8 comp x3/8 comp anglestop!
