Descaling a Bosch 125b
chris salazar
California
I have a Bosch 125b and have looked everywhere on the web on back flushing this unit. I am amazed that for all of these units out there that there is nothing on this subject. I could just try but was hoping someone with experience on this model could help. there is not a back flush kit on this model and so can anyone help?
Master Plumber Mark
www.weilhammerplumbing.com
you need to have the isolation valves installed to do the job properly...
unless you want to tear into the plumbing and basically cut up everything with unions..
lots of jack legs install tankless heaters without the isolation valves,
if you unit is fairly new I would complain to the jack-leg plumber that installed it in the
first place for cutting corners.. I think that the valves are worth about 100 bucks
Stuff
Pennsylvania
The 125B is an old unit so I doubt the plumber can be found.
They have short flex connectors for unions. (braided washing machine type hoses) So to flush you turn off the inlet and outlet valves and then disconnect the hoses.
