Dent on the top of my pressure tank
nbaxley
Illinois
First up, I'm new to replacing pressure tanks, but I've done plenty of plumbing jobs around our house and this forum has been a great resource so thank you for that! I purchased a Well-X-Troll WX-203 to replace our WX-202 that has gone bad. When I opened the box, the very top of the tank was dented. I found another thread here (https://terrylove.com/forums/index....essure-tank-use-it-or-swap-for-another.81589/) that talked about a dent on the side of the air section and everyone seemed to think it's ok but I'm wondering if the top port makes any difference. I'm honestly not sure what it's for. I've asked for a $50 discount from the company but I want to make sure I'm not setting myself up for problems down the road. Pictures attached.
Thanks,
Nate Baxley
WorthFlorida
Solutions
Orlando, 32828
A anchor mounting point if the pump is installed on top of the tank.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
That nut is what they use to hang them to paint, but it can be used to mount a pump as well. The dent on the tank will probably pop out when you pressure up the system. It may have cracked the coating on the inside of the tank and make it rust through sooner. It is on the air side of the diaphragm though. Should not have any moisture up there until the diaphragm breaks from the pump cycling on and off as a WX203 only holds 6-7 gallons of water.
