eR1c
Hello there - I was wondering if I could get some assistance with my issue. I replaced my shower cartridge with the type in the image below. It's an exact replacement and it's all brand new. I followed the instructions and installed everything correctly, from what I can tell.
My issue is that now, either with the handle installed or if I remove the handle and grab the gold stem with a set of channel locks, the whole assembly turns 360 degrees in either direction. So, if I turn it clockwise from the off position, where no water is flowing, the water will turn on again. I thought the water should only turn on when you turn the assembly counter clockwise. When I install the handle, it does the same thing, except there is more resistance due, I assume, to the Alan bolt that is installed perpendicularly through the stem limiting the rotational temperature regulator's rotation. But again, it doesn't stop the cartridge from spinning clock-wise with it installed. It just creates more resistance.
Also, what is that Alan bolt that goes through the stem for? I can't for the life of me figure out it's purpose. I thought it was meant to prevent the stem from turning past the "off" position, however, that doesn't seem to be the case.
I'm sorry but I don't have much experience with plumbing. Thanks for any help you can offer.
