Delta Rough in shower and Tub valve, can this port be drilled to add more flow for the tub?
CaliSkier
Oklahoma
I have been looking at several valves trying to find one that will fill my tub fast, and then I saw this...
It has a port at the top (red arrow) that feeds the tub spout and shower, its a hole that narrows down to a small size (at least on mine it does). The bottom hole, blue arrow is blocked. I was wondering if I could just dril a hole throught that to allow for more water to enter the tub spout. Is this going to cause a problem? If the tub spout is stopped it will send the water to the shower right so no problem, right?
Delta Faucet R10000-UNBX
From prior posts, these are some of the valves that are referenced, if you want high flow rate...
Kohler K-2976-KS-NA MasterShower 3/4 - 17 gpm might be hard to beat...
R10000-UNBXHF with 17t cartridge
From this thread:
