I have a delta R10000 valve, and am installing it in a shower only. I read about the trick to install it upside down due to better flow, and possibly some sort of debris collection prevention that a normal install might lead to.
I found this:
https://terrylove.com/forums/index.php?threads/delta-rough-in-valve-for-shower-only-install.54243/
But am unsure of what Terry's post means by "You can use a threaded brass plug, or make up a male adapter and cap." (edit: I see this is probably means for the shower head rough outlet).
I intend to sweat a copper plug into one of the unused valve ends, is this method correct?
I found this:
