Delta, Hot water coming out cold faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by RedSoxFan1, Nov 15, 2019.
  1. RedSoxFan1
    RedSoxFan1 New Member
    Nov 15, 2019
    Providence
    Hello,
    I had a leaking shower so I called Delta and they sent me out a new cartridge. Upon removing the old cartridge I discovered Delta sent the wrong part. I called Delta back and they are now sending the correct replacement cartridge.
    The cartridge I removed was broken and the plastic half remained lodged in the valve in the wall. It took some effort to get the plastic part out - to the point the cartridge can not be put back into the valve. So I capped the valve and the pipe the shower head goes on so I could turn the water back on.
    For some reason there is now warm to very hot water coming out of the cold side on multiple sinks in the house. Anyone know why that is happening and is there anything I can do to fix it while awaiting the arrival of the new cartridge from Delta?
    Any information is greatly appreciated.
    Thanks.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Close the stop valve for either the cold or hot, if you have one.
  4. Terry
    Aug 17, 2004
    The hot is crossing over at the shower valve.
    They do make a plug for that. I doubt that the homecenters carry it though.
    [​IMG]
  5. RedSoxFan1
    Nov 15, 2019
    Providence
    Thanks for the reply. I'm not sure what you mean by stop valve.
  6. RedSoxFan1
    Nov 15, 2019
    Providence
    Thanks Terry. I will contact my local plumbing supply store. Should I just ask for a rough in valve plug that stops cross over or is there a specific name for that?
  7. RedSoxFan1
    Nov 15, 2019
    Providence
    Perfect. Thanks again!
  8. Reach4
    Sep 25, 2013
    A stop valve is one that shuts off the water. Some valves have them built in, and they are generally screwdriver-operated. They are on the outside of the big hole in this picture:
    [​IMG]
    Some installations have separate valves installed. If you have neither, wait for the cartridge.
  9. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    Possibly one of the most common questions on this site
  10. hj
    The "plug" only works if he has a Delta "Universal" body and the "rough in" body seal to hold it in.
Similar Threads: Delta water
Plumbing Forum, Professional & DIY Advice New Delta single handle faucet thumps When turning on water Aug 16, 2020
Plumbing Forum, Professional & DIY Advice New Delta Shower Valve - Lukewarm water Jan 21, 2020
Plumbing Forum, Professional & DIY Advice No water through Delta shower cartridge Aug 24, 2019
Plumbing Forum, Professional & DIY Advice Water to my Delta handheld isn't working Feb 5, 2019
Plumbing Forum, Professional & DIY Advice No hot water, Delta shower faucet Dec 23, 2018
