No screaming
I have water in leaking in between the wall when diverter valve is i shower setting. Doesn't leak in bath setting. I'm fixing what some one else started so I'm not sure maybe there is a o ring missing or the valve is in the wrong direction, if that even makes a difference. I have checked and it does seem to have all O rings.O didn't think it was the water faucets because it only leaks on shower mode. Don't know the model because i didn't install the unit but the valve has a brass stem and a plastic body with three holes. If that helps
