wilshire
I have one of these in my shower and recently noticed a leak below it above garage ceiling. Noticed it only leaks when showering, more specifically when someone is in the shower, not when shower is running unoccupied. Some testing (pouring a glass of water above fixture on wall so that water runs down it shows that is the problem.
I took off the handle and sleeve and saw that o ring in that position on the shaft. Is it not supposed to be right beside brass nut in that groove? Not that that would solve this leak but thought it was odd. when o ring is slid up into slot, the sleeve won't fit over it as its too fat. The problem is water getting in behind sleeve around the perimeter of the shaft and evidently leaking down below which makes sense wy it only happens when someone showers ie splashing water backawards onto fixture. Other than caulking the seam around the sleeve, is there something else i can do to prevent this?
