Hi
I wondering if you can help me with a question I have with a dehumidistat. I have a 1998 home in Canada and the builder didn't install an ERV/HRV system. He installed a Broan DH100W (manual: https://images.thdstatic.com/catalog/pdfImages/45/451375bc-9409-4369-952c-424f91fd1dab.pdf) in the middle of the house (on wall on the first floor). He also installed a fan in the bathroom and an air intake in the basement controlled by a damper.
When the dehumidistat reaches the humidity set, it starts the bathroom fan and opens the intake damper in the basement. In the bathroom, I also have a wall switch and when I use it, it will start the fan (without opening/closing the damper).
So the fan will run as long as the dehumidistat reaches the humidity level or the wall switch in the bathroom is used.
The damper will open with the dehumidistat reaches the humidity level.
I would like to have more automated control over this setup. I already have Zigbee and Z-Wave smart controls/sensors in my house (no problem for that part, I know how to program those in Home Assistant). My father once tried to replace the bathroom switch with a dumb timer switch but it didn't work. I assume it might be because he did something wrong since this switch is somehow linked to the dehumidistat?
What I would like to know is, is it possible to replace the dehumidistat with a smart control and potentially the bathroom switch as well? I don't need the humidity level feature, a simple on/off switch would work for me (feature wise) but is it possible with the current wiring? The main goal would be to have
1. A z-wave or zigbee control ("switch") instead of the dehumidistat
2. If possible (but not as important) have a z-wave or zigbee switch in the bathroom for the fan
