Blueoval78
Hello everyone, I recently went through a power outage where I tried to run my 110 volt 1/3 hp convertible jet pump on my 3000 watt generator. When the pump tried to start, it ran slowly and smoke came out of the motor. It eventually got up to speed but since then it has the burnt smell when it runs on normal house power. The motor has 8.2 amps under SF on the tag so I figured my generator could easily handle the pump thinking start surge might be double or triple that at most. Last night I put a clamp meter on the hot wire and it runs at 10.2 amps with a 63 amp start peak! No wonder my generator couldn’t handle it. My question is, does this amperage draw seem normal for a 1/3 hp motor running a convertible jet pump on a 45’ deep well? The pump appears to be running perfectly normal. Thanks in advance for responses.
