Mculik5
Need some help regarding best solution for oil-fired heating for my situation.
Here's my situation:
Live in NJ. Been in this house for a year, and plan to stay here for a LONG time. Heat exchanger on old oil-fired furnace is cracked. Had an independent manual J done, and the heating load is 80K Btu. Current heating system is one zone for the entire house (3200 sqft). It worked well enough last year that I'd stick with one zone if that's the best way to go given my design goals below.
My design goals, in priority order, are:
1. Efficiency - reduce energy consumption as much as possible to save $$$ (especially if/when oil prices go up again)
2. Low total cost of ownership - factoring in initial cost, maintenance costs, fuel costs, etc.
3. Comfort - obviously, but willing to make some sacrifices if necessary to save $$$
4. Longevity - I want a system that will last a LONG time provided I keep up with maintenance (which I will)
5. Low initial cost - I'm a buy once, cry once kind of person; would rather spend more $$$ initially (to a point, of course) to do it right
Here are the options I'm considering:
1. Replace existing furnace with a new oil-fired, right-sized furnace.
2. Same as option 1, but add zoning (whole house is currently one zone).
3. Install an oil-fired boiler, outdoor reset, hydronic furnace for the first floor (in basement, using existing ducts), and hydronic furnace for the second floor (in attic, using existing ducts). Possibly incorporate indirect hot water (vs. electric now).
Which one would you pick, given my design goals?
Notes:
- Sticking with oil as the fuel
- Sticking with forced air as distribution method
Notes:
