HilltopRehab
I've demo'd our original 1958 master bath, and before I start to build up I want to address the old plumbing.
It's a 3/4 bath with a very small footprint, leaving not many options for reconfiguring so I will be leaving the layout as-is, aside from moving the shower plumbing from a partition wall that formerly framed the shower stall - planning on enclosing with glass partition and door.
After pulling up some of the old 3/4" plank subfloor that was water damaged and questionably supported, I can see that the shower drain is only 1.5" copper pipe, granted that's eyeballing a tape measure on the OD. I'd like to increase the pipe diameter and do it the right way, either myself or by a pro, so that brings me here seeking advice.
The WC drain pipe is 4" and the flange is at a height that I think I can work with, but I'm wondering:
Thanks for any advice!
- Should the whole branch be re-worked to incorporate a bigger shower drain and replace all three drains with PVC - see photo, both the sink drain (1.25") and the shower drain tie in just downstream of the WC flange on their way to the main stack.
- Should I try to un-thread the shower drain and see if that's already a 2-inch opening, is the right thing to do here going to be to replace the copper drain with PVC anyway?
- Or, should I try to minimize the amount of work and stick with the existing WC flange, using an adapter to go from the 1.5" shower drain connection point to a new 2" PVC drain?
