I got up this morning to use my one working shower to find out it wasn't working. Both hot and cold water were coming out of the tub spout but nothing from the shower head. Turned the tub back on to see pieces of rubber coming out.
Got home from work and pulled the diverter stem (which I replaced 1 month ago, along with the hot and cold stems), nothing wrong. Then pulled the hot and cold, the rubber stop on the hot is shredded. Its only a month old. I could not get the original seats out so I left them in place. They felt find so didn't think there would be any issue.
Is that the cause? The other two are fine and were against original seats.
Anything else that could cause this? The shower worked just fine the night before.
The line is connected to the 3/4 lines I recently soldered for my Master Bath reno. I worked hard to keep debris out of the lines but some copper from deburring could have gotten in. Maybe that is it?
Is there a way to flush the lines before putting the stems back in and replacing the bad one? The valve sits about a half inch back from the finished wall which is tile on mud. Don't mind trying to flush them but don't want a watery mess, suggestions? I have access from behind because if the master reno.
