FingerLakes
I have a shallow lake well with a 2 wire (2 wire &ground) submersible well pump.
I was repositioning the pump in the well recently and noticed a small "bite" in the 12awg (3 wire) pump wire feeding the well pump. Inspecting closer, I found a cut in the pump cable that through the outside insulation jacket and penetrated into the green ground wire exposing some of the stranded copper wire. The damage is confined to the green ground wire and not the other 2 hot wires. The portion of pump cable with the damage is near the pump and completely submerged in the water. The pump operation is fine so I dropped it back in the well. FYI I was moving the pump as part of a seasonal water level change routine, not anything electrical related.
My question is, is this super dangerous, like an emergency situation that I need to address immediately?
I do intend to splice in a new undamaged section of well cable, but I need to buy a splice kit, some pump cable itself. I was going to make this repair in the coming weeks when I have more time. Is this something urgent, should I make it a priority?
Thanks for your help.
