Last year I got a call from a CSV customer. He has three houses, all with pump and dump heat pumps. For the last 15 years, all three houses have been using Cycle Stop Valves to keep the well pump from cycling to death. This year one of the well pumps finally failed for some reason. The home owner had been using Pentair pumps, and since they lasted a good amount of time, he had a new Pentair pump installed in the well. Within a week the new pump failed. Installer replaced it, and sent it in for a warranty. Within another week, before they even heard back from the first warranty, the second pump failed. Having had two failures in such a short time, the installer got the distributor involved. The installer, distributor, and a Pentair rep show up at the customers house. The others hadn't even got in the well house before the Pentair rep, was saying "warranty is void because you have a CSV".
I was on the phone with the customer and heard all of this going on. On speaker phone I hear the Pentair rep telling everyone there that Pentair will not warranty any pump with a Cycle Stop Valve. Again, I asked if she could get me that in writing?
During all of this the homeowner was explaining to everyone that this was one of three houses he owned. He said all three had CSV's controlling the pumps for the last 15 years with no problems. It didn't matter to her. She was insistent that the CSV was the reason for the failure of all the pumps. I asked her what about a CSV would cause her companies pumps to fail? "Not enough flow and overheating the pump and motor", was her quick answer. I said "well, then an autopsy on the pump should easily show heat damage right"? She agreed and since the homeowner was standing there, they would take the last two pumps to the factory for inspection, and let me know the outcome.
A few weeks pass, and I finally here from the homeowner. Pentair said the capacitors in the two wire motors failed. They got a batch of bad capacitors that would not stand up under continuous duty. As I already knew, the failures had nothing to do with the Cycle Stop Valve. There was no heat damage to the pump/motor whatsoever. The homeowner got an apology and a free pump. I didn't even get a call back, much less an apology from Pentair.
I am sure she was taught this by the company she works for. After 25+ years, I am still amazed at the things these companies will say to keep homeowners from getting a CSV. And since I didn't get an apology from Pentair, I am using this to let everyone know the pump manufacturers will tell you they won't warranty their pump when using a CSV, because they know the CSV will make the pump last longer, and they don't like that.
