I just finish replacing a section of cracked 4" cast iron pipe. Do a search for that thread. Lots of good recomendations. SOme better than others. Here is what I learned.
Chain snap cutter is best, but old pipe can collapse on you. That is what happened to me. ONe good clean cut, one bad cut and the cut line went the wrong way and I have to cut the pipe further back. Maks sure there are plenty of pipes left.
Once the snap cuter goes bad happened, you'll have to use a grinder with a carbide disk. I got the sawzall blade with carbide grit blade, very slow and tiring. I gt the metal blade for cutting metal and cast pipe. Not as slow as the sawzall but still slow. The carbide embedded grits heats up and melts off or the molten cast iron material clogs up the teeth. 4" grinder is MUCH faster. I had a 3/16 thick disk. Friend told me to use a thinner disk. Less material being taken ot and it will create less heat. Thinner disk is easier to break. Either way, do not twist the grinder when the blade is in slot. Wear eye, or even better, face protection.
If this is a pipe you want to destroy and not use, a sledge hammer. I broke up a section so it is easier to handdle when I pack it n the garbage. My friend have a stone work hammer with a sharper tip. It also worked well in cracking up the cast iron. Easier than a sledge, lighter.
