Close to getting the DWV piping air tested. I cut out a 10" section of that cast, and put Fernco's over the cut ends. I torqued them to the required torques - should I have tried to make sure they were smooth? Is it likely that air will be leaking there?
I have a gauge and Schrader valve contraption put together, and I load the system up to 5psi, and around 7 minutes in I can see it falling. At the 15 minute mark it is down to 4psi. I need 15 minutes to pass. Some soap water at one of the cleanout plugs was bubbling ever so subtly, and I could hear it, so I taped and doped those plugs threads, and torqued her back in (not sure it was wise to dope a cleanout plug), re-loaded and same thing, drops to 4 by the 15 minute mark.
I've soaped the valve/gauge contraption (which is heavily doped) and I see no bubbles anywhere.
If I go back to the cast iron and try to beef up the seal, is there anything else I can do (like if it was threaded pipe, I'd add dope)?
Thank you for any advice - I have around 85 pipe joints on this plumbing, and I've gone to around 60 of them with soap-water and other than that cleanout plug, no leaks detected. I'm thinking the cast iron with the Fernco covering it is where it is leaking, and this is driving me nuts.
