spylake farms
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Is there a procedure I can perform on an existing pump that will tell me if it will exceed the relief valve pressure or worse the 160 PSI rating on my poly pipe when throttled back to 1 gal/min?
The well has a 2.5 hp pump at 75 feet and a static water level of 20 feet.
However I do not have a pump pressure curve for this specific pump.
Second question. I want to replace the existing pump with a Water Ace R203A 1 hp set at 150 feet. I estimate draw down will be ~ 50 feet at 15 gal/min.
(pump was chosen because it is one I have on hand)
specs on the pump can be found at this URL
http://www.waterace.com/pdf/23833A019 Well Pumps Eng.pdf
