With no CSV, the pressure to your showers/faucets will drop from 70 to 50 psi, then once the pump is activated, the pressure will again rise from 50 to 70 psi. Once the pressure switch shuts off the pump, pressure will again drop, and so these cycles will be repeated for the entire time water is being utilized.
A CSV will reduce the flow rate directly from the pump, to match the exact GPM that is being consumed at any particular time. This is achieved by maintaining a specific pressure after the CSV.
With a CSV, initial water use will again cause pressure to drop from 70 to 50 psi, but once the pump becomes activated, the CSV will maintain 60 psi constant downstream, regardless of whether 1 or multiple showers, faucets or appliances are being utilized at the same time.
Because the CSV is controlling the flow rate to maintain 60 psi downstream, pressure will not rise to 70, and so the pressure switch will not shut off the pump. Once water is no longer being utilized, the CSV will continue to permit 1 gpm to pass through, which will cause the pressure tank to fill until 70 psi is achieved, whereby the pressure switch will shut off the pump.
While a CSV maybe utilized with your existing 56-gallon pressure tank, because the CSV will prevent the pump from cycling, a large pressure tank is not needed, and actually, your pressure concerns will be best satisfied by replacing your large pressure tank with a small one such as the 10-gallon tank often included with the CSV PK1A Pside kick kit shown
HERE.
A 4.5 gallon pressure tank is also offered, but the 4.5 is typically recommended for 40/60psi or lower pressure systems. For a 50/70 psi system, then a 10-gallon pressure tank is normally recommended.
Your exisiting 56-gallon pressure tank will store approx 14-gallons of draw down. If the tank is completely filled to 70 psi before the start of your shower, then ~14 gallons will need to be consumed before the pump becomes activated at 50 psi. A typical shower head flows @ 2.5 gpm, so that 14-gallons will probably represent over 5-minutes of shower time at declining pressure before the pump becomes activated and constant pressure is supplied.
A 10-gallon pressure tank will only store about 2.5 gallons drawdown, so a shower will usually only need to run for about 1-minute before the pump becomes activated and constant pressure may be enjoyed in the shower.
CSV Interactive Animation
