The picture Bob NH posted is not plumbing, I don't know what it is, but it is not plumbing.
I've seen a lot of people try different ways to bash PEX, but come on, using a picture like that and saying it is a typical install is... You enter your own word or words, I don't want to O-fend anyone.
I'm not trying to bash PEX, but there are some on this forum who bash CPVC without citing any published data.
With respect to the picuture:
1. I didn't say it is a typical installation.
2. It is a link to a picture that was posted on this forum by Master Plumber Mark in the Pig Slop Award thread
https://terrylove.com/forums/showthread.php?t=17722 that he originated. I never suggested that it was either typical or good plumbing.
3. I wasn't trying to bash PEX. I was simply pointing out that the use of manifolds of that type, which seems common in PEX installations, results in a lot of PEX tubes that go off in one direction from the manifolds that have to be turned in various directions from the manifold to get where they are going.
That is in contrast with the usual practice in copper and CPVC where a larger pipe is installed as a "main" with branches off at appropriate points wherever is most convenient for routing.
There are a couple of reasons that PEX is installed off manifolds.
1. There are fewer PEX fitting connections and therefore lower cost of fittings and stops if one uses the manifold system.
2. The smaller inside diameter of PEX compared to the same size of copper or CPVC limits the flow that can be used with 1/2" PEX, leading to more "home runs".
