dauber man
I’m planning on installing a metal shut off valve right after the water meter (see photo). A few questions…
1) I’m planning on using a metal ball valve with cpvc connectors (Sioux chief makes one). Is it as simple as cutting and solvent welding on the valve?
https://www.supplyhouse.com/Sioux-C...etalHead-Full-Port-Brass-Ball-Valve-Lead-Free
2) Will cutting the pipe affect the expansion tank at all? Will it need any sort of adjustment afterwards?
3) I was thinking of adding more pipe (in the shape of a U) to place the shut off valve at a lower level for easier access.. Will adding this cause any issues with water flow?
Thank you for any assistance here…
