Working on some diagnosis. Extremely high static electricity in rooms. Sight pulse of electricity felt in back when laying in mattress or standing on carpet. Sensation of electricity pulsing very slightly. Anything strike you as odd?
Kelin tools no-contact voltage detector 50v-1000v flagging aggressively when touched to wire with TV or other appliances when they are off. If touched to iPhone charger, flags consistently even without iPhone plugged in. Charger was plugged in and sitting on carpet. Does this mean stray voltage is being released even when the device is not plugged in? That normal? Seemed to drastically reduce when everything was totally unplugged in the room. Also the detector flags on body, legs, hands, mattress, but usually only when “rubbed” or “moved” not a steady voltage detected. Slight pulse of electricity felt when laying down or standing. Amazon fire stick had consistent aggressive beeping when even 4-5 cm away. Could this be leaking voltage into extremely dry air?
True meter plugged into top left socket of outlet, device placed on ground zeros out. Second prong touched to arm shows >50v.
“Jolt” sent through one outlet to beard trimmer while in use shaking trimmer and user’s hand.
Let me know if any other pieces of info might be helpful.
