Countertop single-handle beverage faucet w/ tapered or compression fitting?
Ha6P4
Arizona
I'm installing an under-sink chiller and need a full pressure-rated single-handle beverage faucet.
Common beverage faucets connect with low-pressure soft tube from a RO filter, which I can't use unmonitored with 80+psi supply pressure.
Are there any countertop cold single-handle beverage faucets w/ NPT or male compression fitting?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Any 1/4" "filtered water dispenser" tap will take normal pressure. PRV on main line is required and always recommended over 80 psi.
Simply avoid, insta-hot type faucets.
