Could very old toilets have 2-inch waste pipes?
gadolphus32
New York
There is a room in an old house that I own that looks like it was at one time a bathroom, although now it is empty and used for storage. I'm curious about its history.
In addition to abandoned water supplies that serve the room, there is a waste line running to it that has multiple outlets. One I assume would have been for a sink, and the other for a toilet. The only strange thing is that the line is only 2 inches in diameter.
So my question for you experienced plumbers is: Do you ever encounter old, old plumbing where they used a 2-inch waste pipe for a toilet? I know you absolutely can't do that today (and I wonder how it even would have worked back in the day). But I'm just curious.
I realize it's possible that the multiple drain lines in this room served fixtures that did not include a toilet. I'm just trying to figure out what is possible based on the information left in the plumbing lines.
I am not a plumber, and I don't know the answer to your history questions.
There are toilets and systems that have grinder pumps. Those can pump the ground up toilet waste via pipes smaller than 2 inches.
Good point. I forgot about those. But while I don't know the history of grinder pumps, I suspect they did not exist, or at least were not in household use, 100 years ago.
Who knows really what was done 100-years ago before plumbing codes came into existence. Today, though, you'd need at least a 3" drain line to install a toilet. I think a 2" line would be problematic, but maybe better than going to an outhouse in the middle of winter in NY.
Someone I know who had traveled in Greece told me that the toilets there had 2" drains. Used tissue goes in a waste basket.
May have been at the time when people didn't put toilets in bathrooms. Some thought it was unsanitary. It might have been a washroom with sink and tub. Probably where the laundry was done as well.
