Hi,
Less than 3 years ago I replaced my pressure tank because it was rusting at the threaded connection where the brass tank tee is connected (which caused a slow drip leak). Pipes on either side of tank tee are 1" black plastic. My water is on the acidic side (6.7) and hard (16GPG), and I've installed an acid neutralizer and water softener downstream of the pressure tank.
Well, the "new" pressure tank has corroded AGAIN at the SAME location and is slow-dripping again.
This is frustrating and I cannot imagine this is normal/to be expected.
Is it, maybe, a galvanic corrosion issue between the brass tee and the pressure tank and, if so, should I get yet another new tank and install a stainless steel tank tee instead?
Any/all advice appreciated.
Thanks
Theodore
Thanks
Theodore
