stardog
Reporter
Using a standard PVC coupling I will be connecting 1/2" ENT flexible tubing to 1/2" schedule 40 PVC. I plan on using plain Oatey gray PVC solvent to do so. I presume this would be the correct solvent for this application? If not, then which solvent should I use? I need to connect the two for a short run of ENT inside the attic.
I believe Carlon recommends a blue cement for strictly ENT>ENT connections, but not sure for ENT to PVC. Tks.
