Corian tub/shower surround installed over Redgard
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bluebinky, Feb 3, 2017.
  1. bluebinky
    bluebinky Member
    Aug 31, 2011
    Electrical/Embedded Software Engineer, Retired
    Des Moines, WA
    The wife comes home just after I finish waterproofing the Hardieboard tub surround and decides that a solid surface surround is the way to go after all. It doesn't seem that silicone will adhere properly to the Redgard.
    Should I go over the Redgard with skim coat of (modified) thinset, or any other ideas?
    Thanks in advance.
  2. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
  4. MKS
    MKS Member
    Apr 15, 2016
    Illinois
    Would covering the redgard with 1/4 inch backer board be a deal breaker?
  5. dj2
    dj2 In the Trades
    Aug 13, 2013
    California
    You can you use modified thin set (powder type, not the premixed) over redgard.
  6. bluebinky
    bluebinky Member
    Aug 31, 2011
    Des Moines, WA
    Thanks. That is what I was originally planning to do for putting up tile.
    Any idea how well dabs of silicone will adhere to a skim coat of thin set? Which would stick better overall, modified or unmodified?
    As for putting up more backerboard, it would seem much better to not penetrate the water barrier. It would still probably be better than using greenboard, as the manufacturer suggests.
    I'll search on the johnbridge forum.
Similar Threads: Corian tub/shower
Plumbing Forum, Professional & DIY Advice Tub/Shower Surround: Swanstone, Corian, ??? Aug 26, 2007
Plumbing Forum, Professional & DIY Advice Corian type melts into 1 piece shower, minus Corian price? May 25, 2021
Plumbing Forum, Professional & DIY Advice Corian bathroom sink - overflow adapter leak Dec 22, 2019
Plumbing Forum, Professional & DIY Advice Corian and disposals Jan 12, 2016
Plumbing Forum, Professional & DIY Advice Any thoughts about CORIAN sinks? Nov 23, 2008
