Copper pipe too short to attach a coupling and extension?
DRussell
California
I am fixing an angle stop valve that was professionally installed about four years ago. The stem broke when I turned it on after having it off during vacation. This is a cold water supply valve to a washing machine. I wish these valves were made better, but I know that our hard water is partly to blame. The valve is compression-fit to the copper pipe. The stub sticks out about 1 & 1/4" from the wall, but more than half of it is compressed by the fitting (see shiny part on photo), rendering it too small in diameter to solder. I would need to cut off the compressed part and sweat a new coupling and short copper pipe on it, as I have done with other valves in the house. But this one is the shortest stub yet. Is there any way I would not need to cut away the wall and solder behind the wall's outer surface?
DRussell
California
I would cut 1/2" off the end so the compression ring fits further back. You might need a flatter escutcheon.
Thanks! That sure saves time sweating (in all meanings of the word). The nut might be so close to the wall that I can't use an escutcheon, but I will try this before cutting away the wall.
Dj2
California
A neat solution would be to go with what's called " Dual Outlet Washing Machine Outlet Box", for which you will have to cut the wall (this box goes inside the wall) and modify the pipes inside the wall to fit.
You can even get one with Hammer Arresters.
SteveW
DIY Senior Member
Omaha, NE
I did this myself -- used a nice Oatey WM box with quarter-turn valves. Had to cut and patch some drywall but was very much worth it.
