Copper joint. Was it lead free?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIYorBust, May 5, 2021.
  1. Tughillrzr
    Tughillrzr In the Trades
    Jan 29, 2020
    New York
    Just sold a house and a bank was asking for this to be signed. It was brand new so you’d assume all fittings are lead free.
    Jeff H Young likes this.
  2. Jeff H Young
    Jeff H Young In the Trades
    Feb 27, 2020
    yes interesting , And I could sign that on a home I built but on a 40 year old home that I didn't build I'd have to be lying . even if I could inspect a copper joint Id be guessing about the rest of a home being "Lead free"
  3. jadnashua
    There are tests for lead paint, and the paint itself will have a fairly small percentage of lead, so I think the tests would detect it in solder. It wouldn't hurt to call them and ask. More than one company makes lead tests, and one might be more suitable for your intended task.
    On a home that old, I would not be comfortable certifying that everything in it was lead-free...just too many things, and you may not be able to test them all. I'd consider passing on the job...too much liability unless I understood the guidelines better.
  4. Tughillrzr
    Jan 29, 2020
    New York
    True. Also how do I know if I didn’t grab a non lead free fitting on accident? Or like you said how the heck would you know what’s been done to house if your a second or third owner. Gotta be some gadget out there to test.
  5. themp
    themp Member
    Feb 5, 2008
    Raleigh, North Carolina
    House built in 1984. The city I live in decided to test older homes for lead. I had to draw water from the kitchen sink first thing in the morning after sitting in the pipes all night. My home passed. You can get a water filter that will remove lead. But I think it will remove flouride also.
  6. DIYorBust
    DIYorBust Active Member
    Mar 5, 2019
    Long Island, New York
    Thanks folks, yes it's an annoying situation, I may have to speak with an engineer about whether they can test and sign off, I can see why a plumber would not want to do this.
  7. Jeff H Young
    Feb 27, 2020
    DIY even a test like themp stated might not agree with paper you need signed all it means is no water was found to contain lead not necessarily that your copper joints weren't soldered with solder containing lead . So unless the person reads what they are certifying no way of knowing. for example I can't certify that I plumbed your entire house with lead free solder if I didn't plumb it.
    sharing the info you have like the exact form you need signed would help even 26 posts in if you noticed we have been guessing and trying to help , don't even know if this is just a city , county ,state form or what.
    Sylvan likes this.
  8. Tuttles Revenge
    Tuttles Revenge In the Trades
    Oct 15, 2014
    I tried looking up the same paper and the law/code behind it but I failed. I don't think it would be possible or reasonable to have a requirement that wants you to verify something that you can't verify. I'm of the opinion that the document is asking that you verify that the NEW work you've installed is lead free.
  9. mikha'el
    mikha'el Member
    Jan 27, 2015
    Texas
    In my house that would be considered a good thing. ;)
  10. Jeff H Young
    Feb 27, 2020
    yea but he isn't going to tell us just leave us scratching our heads guessing what he wants. still vague 30 posts in
    Tughillrzr likes this.
  11. Sylvan
    Sylvan Still learning
    Sep 23, 2004
    plumbing - fire suppression - boiler inspector
    New York
    A legitimate plumber would never take on the liability of signing off another plumber's work.
    The exposure to a lawsuit would not be worth it.
    Tuttles Revenge likes this.
  12. Sylvan
    Sep 23, 2004
    New York
    Terry NYC in the early 1970's allowed Copper type L to be installed but it had to be brazed and allowed 50-50 for one family residential buildings
    Due to the safe water drinking act 50 - 50 was outlawed and in lieu of brazing 95 -5 was allowed
Similar Threads: Copper joint
Plumbing Forum, Professional & DIY Advice Copper Joint OK? May 1, 2021
Plumbing Forum, Professional & DIY Advice PVC to copper joint needs sealed Dec 28, 2020
Plumbing Forum, Professional & DIY Advice New copper Joints Aug 30, 2020
Plumbing Forum, Professional & DIY Advice Finishing Basement, Easy Fix for Leaky copper to cast iron joint? Mar 28, 2020
Plumbing Forum, Professional & DIY Advice Copper, should I replace these joints or what? Signs of a rookie plumber Oct 28, 2018
