Converting floor drain to cleanout
Clax66
Toronto
hi guys,
I have a 4" PVC floor drain. for reason I won't get into I want to convert it to a clean out. The PVC pipe is flush with the poured concrete floor. What product would be best to accomplish this? It would be nice if it had a nice brass or stainless steel cover.
Sylvan
Still learning
New York
Consider an inside caulk Cast Iron Clean out and and cut around the PC do it can be set level
Bcarlson78248
Alexandria, VA
Its not really the answer to your question, but when I installed a basement floor drain I used this one by Sioux Chief
It is floor drain with a plug you can remove to use it as a cleanout. It also has a knockout for a trap primer.
Bruce
Clax66
Toronto
This will be a polished concrete floor in a finished laundry room so it will need to look good and be fairly smooth and level with floor. I have products online but unsure how they would work with a existing poured floor. I can chip around the PVC pipe but would prefer to keep this to a minimum. cutting the pipe down can be done as well as I have an inside pipe cutter
Clax66
Toronto
the Cast Iron Clean out is the right idea but a little too rough looking.
I wish we had put in the Sioux Chief when we had the chance. the floor has in floor heating so breaking the floor is kinda not an option
If that reason is a concern for backups, you might be able to put a test plug into the bottom of the drain bowl.
Clax66
Toronto
is this test plug permanent? Permanent in that it will hold until I decide to take it out. There is a 'possibility' of backups and I don't want to take any chances.
I think they are long-lived. You need to get the size right. There are ones sized by nominal size, and some sized differently.
Sylvan
Still learning
New York
GET A Flush plug to prevent tripping It was just to give you an idea on how to do it
Clax66
Toronto
Thanks Sylvan. That looks good but my floor is finished. That product looks like it needs to be installed prior to the floor being poured. I am just a DIYer so maybe I am not understanding the product. I was hoping there would be something like a toilet flange that glued inside the 4" PVC drain. Maybe a little chipping of concrete to allow the cover to be flush with the floor surface. What do you think about this one?
Zurn CO2452-PVC PVC Adjustable Finished Area Cleanout with Nickel Bronze Cover, 3" x 4" Solvent Weld Pipe Size, 5-3/16" Diameter
It looks like I will need to cut the pipe down a few inched below the surface. Its hard to tell from the description.
Sylvan
Still learning
New York
Same indea. a little chipping around the pipe and set the CO over the piping as we do in replacing roof drains all work from the top
Your floor drain should have a trap under it so it would be completely useless as a functioning cleanout, unless the trap is removed and replaced with an elbow.
Clax66
Toronto
Plumber friend told me the drain would work since it was 4" PVC. Likely not perfect but would work. The main thing is that it gets covered with a good seal.
6a00e550bbaeb388340115721942a8970b-120wi
Some floor drains have a cleanout plug in the bowl, that bypasses the trap.
Some, but not all, in fact, very few, and I would never even consider trying to "snake" a drain through a "P" trap. I doubt that your "plumber friend" has ever unplugged a drain line.
Sylvan
Still learning
New York
We snake through P traps almost on a daily basis going through the trap inlet NEVER though the CO plug under the traps
What happens when your retrieving the cable and there is a big clump of hair on the end of the cable ? It will not come though the small opening most P traps have
Removing the trap causes another problem as 99.% of the traps are brass screwed onto on a galvanized nipple and once the trap is removed to snake the line the galvanized threads are gone from electrolytic action so now we are replacing the nipple and trap
So we compromise by removing the waste fitting above the trap and then snake the lines though the trap inlet
Yesterday I was on a job and and used a trap leader on my 1/2" cable to allow me to easily pass through a 3 " cast iron P trap for a floor drain
With the right sewer /drain cleaning cables or even using a General Ram Jet most P traps are very easy to pass a cable thought it is what is behind the taps that can be a challenge such as short turn fittings or back to back installations
Clog chopper easily makes turns though 3" openings
https://drainbrain.com/en/generals-clogchopper-tieger-tail/
If the stoppage is not roots or a rag etc then the Ram jet will work as I have 6 of them ( 3 are for sale)
http://old.drainbrain.com/why/waterramsuccessstories.html
Also I use a Water Cannon 2 HP electric Water Jetter 2 GPM with a 1/8th stainless steel hose (made by Mustang) hose and it fys thought reaps and ells . The rubber hoses also work but have a lot more friction
Want to buy a General Super Vee :)
