Chris Morris
Hi all, first time poster, long time reader
I currently am in the process of renovating my 1969 townhouse/condo and have a question regarding the current plumbing setup.
I have replaced all the half corroded, horribly laid out trunk and branch copper with a home run PEX manifold system.
I am having some slight issues with flow rates with multiple fixtures/runs in use at the same time.
There is a JOSAM 88250 continuous flow Trap primer for my basement floor drain installed 6" from my water main shut off valve.
My question is would this trap primer cause any sort of flow restriction/pressure drop in my system?
From everything I have read, they are usually installed at or near a fixture, and not on the main supply. Should I look at possibly relocating the primer to my laundry tub or washer run as opposed to the main water supply to the cold water manifold?
Any advice would be greatly appreciated
