Good morning everyone.
2 years ago we needed to tap into one of our shallow wells in order to run a new water line to our greenhouse. With the help of this forum we got everything installed and it has been working great however I did make a big mistake that we are now dealing with.
The walls of the shallow well are concrete and after running the poly through the well wall I forgot to seal around the hole in the well casing. Now we have ecoli and total coliform in the water. I would like to fix this and have already taken a few steps.
I installed a UV sterilizer which is working as it should to kill everything off. I also purchased liquid pool bleach at 13% hypochlorite which I will use to treat the well.
I am going to drain the well and climb back inside on the ladder in an attempt to seal around the pipe.
What should I use to seal the pipe? Would hydraulic cement work? I can also excavate the outside of the pipe where it enters the well and seal it there as well, I just don't know what to use.
I should also say that in 2019 this well will be discontinued and used for irrigation only as we will be putting in a drilled well however I still want to address this issue so we can salvage this well as a backup in the event of drought years.
Any advice is appreciated.
